Best on road shocks?
Old Mar 26, 2016 | 08:13 PM
Redduc's Avatar
Default Best on road shocks?
So Ellie is gonna need shocks in the near future. I'm not going to lift it and only do some light off-roading. What's everyone's choice for an on road upgrade?
Old Mar 27, 2016 | 07:37 AM
Andy2Rover's Avatar
Same here......at 110k miles, my shocks are toast. Looking for on-road shocks, no lift.
Redduc, should probably replace coil springs too as they are most likely toast.
Old Mar 27, 2016 | 08:21 AM
LR03NJ's Avatar
Looking at shocks earlier and saw Bilstein shocks for rover. they said its the best but the price for a set is almost like having a complete Old Man Emu medium duty setup.
Old Mar 27, 2016 | 10:31 AM
jamieb's Avatar
Please post what you find. My road tires are practically new so I won't be swapping tires for probably 2 years. I also run 18-inch wheels. I was thinking a 2-inch terra firma lift kit for $500 but now thinking just put a stock OEM shock/spring set. My shocks are shot.
I am sitting at 32.5 inches ground to wheel well height. 34.5 inches with a 2 inch lift would look funny with my wheels and tires.
I read Bitpart has a 1.5" kit and OME no-lift is another option.
Problem is I can't find a replacement, medium duty, no-lift shocks and springs kit for the same $500 as the 2-inch kit. Anyone find a replacement kit for all 4 wheels, no lift, for $500?
Old Mar 27, 2016 | 10:43 AM
abran's Avatar
Bilsteins are the best I have experienced, but expensive as stated.
Old Mar 27, 2016 | 11:15 AM
Dinoco's Avatar
Put the standard Terra Firma shocks/struts on my D2 last year. Really happy with them and didn't break the bank.
http://www.roverparts.com/Parts/TF224
Old Mar 27, 2016 | 12:05 PM
jamieb's Avatar
Terrafirma Shock Kit, All Terrain For Discovery 2, Front And Rear
That's awesome. Now I need to find 4 springs for $250 to get shocks and springs combined for $500.
Wonder if I can buy the 2" terra firma lift kit, put only the shocks on now then put the springs later when I change tire size? These shock kits say the shocks can handle 2" of lift so the shocks should work the same on a no-lift and lift truck?
Old Mar 27, 2016 | 03:55 PM
Redduc's Avatar
Thanks for the replies. I'm a Bilstein fan and have had them on a few cars, but it would be tough to justify the expense. I'll likely go with the Terra Firma's.
Old Mar 27, 2016 | 06:32 PM
Fallstaff's Avatar
Pleased with my Terra Firmas. Were cheap shipped from the UK.
Old Mar 27, 2016 | 10:25 PM
Dave03S's Avatar
I put brand new bilsteins on old original springs and wore them out in less than 10k miles.
I would not recommend you put new shocks on a high mile original spring truck.
Especially expensive ones.
I have OME MD +2 and after 2.5 years they are starting to ride less stiff. So shop around and know what you are looking for. Stock OEM replacements are a fine option and Lucky8 has them cheap.
If i had it to do over again, for a minimally offroad vehicle, I would get those L8 stock replacement springs and Bilstein shocks.
