Best way to change calipers
Old Nov 1, 2007 | 06:11 PM
sfxgamer's Avatar
Default Best way to change calipers
Anyone know the best way to change calipers? I have a 96 disco and I just need to replace my fronts. Is there a quick step by step guide to help me? Thanks
Old Nov 1, 2007 | 07:11 PM
Default RE: Best way to change calipers
Where are you getting your replacements from? How are the current pads and rotors? How long has it been since you greased your front wheel bearings?
Old Nov 2, 2007 | 06:45 AM
Landzu's Avatar
Its straight forward after that you will bleed the lines.
Old Nov 2, 2007 | 09:17 AM
tads's Avatar
Any suggestions on where I can get good brake pads for my 96 Disco? Thanks!!
Old Nov 2, 2007 | 02:44 PM
sfxgamer's Avatar
My pads and rotors are fine had new ones installed in May of 07. My caliper is leaking brake fluid on the right front side bad. I have to press the pedal to the floor to barely stop. I have no idea on how to bleed the brake line.
Old Nov 2, 2007 | 03:09 PM
Landzu's Avatar
Its a two person job.
After you have the caliper on and brake line one and the master cly
full.
Find the nipple on the caliper (on top) one person pumps the brake
pedal and then holds the brake pedal as the other person lets air and brake fluid out of the nipple, the brake pedal will go to the floor
hold it there until the nipple is shut then start over this may take 10 to 15 times keep the master cly full of fluid.
Old Nov 2, 2007 | 03:10 PM
Landzu's Avatar
Dot 4 brake fluid.
Old Nov 2, 2007 | 03:23 PM
sfxgamer's Avatar
Thanks!
TRIARII
Dec 17, 2012 06:33 PM
collin Barrows
Aug 28, 2011 07:13 AM
drdabbles
Aug 17, 2010 07:37 PM
jrkstore43
Apr 3, 2009 02:04 AM
gsxrgessler
Jan 26, 2008 08:34 PM
