Better radiator... options?
Old Dec 7, 2013 | 02:43 PM
Disco_Fever's Avatar
Default Better radiator... options?
What are our options for a higher-capacity or otherwise better-than-stock radiator?
Old Dec 7, 2013 | 04:56 PM
Externet's Avatar
Hi.
Higher capacity... yes. Better than stock, I believe so. For very sure, it is not worse. Nothing plastic on it, wide gap tubes. Been six months running with zero leaks, problems nor overheating:
----> Left Mount Photo by Innernet | Photobucket
Old Dec 7, 2013 | 05:53 PM
dr. mordo's Avatar
Man, you have some crazy photos in there.
What do you do with the ECR-1?
Old Dec 7, 2013 | 06:02 PM
jfall's Avatar
Get the Nissens from Rockauto.com
About $230.
Perfect OEM fit.
No issues.
Old Dec 7, 2013 | 06:24 PM
dr. mordo's Avatar
I think the point is he wants higher capacity so it cools the coolant more efficiently.
I personally think an electric fan will give a similar result but with less effort.
Old Dec 7, 2013 | 09:54 PM
mbruneaux's Avatar
Twin "pusher" fans would be a great replacement for the mechanical "puller" fan. I don't know what the dimensions would be but I'm sure there is something out there that an work independently from the Rover system. It's a question of fit.
Old Dec 8, 2013 | 12:01 AM
dr. mordo's Avatar
Why would pusher fans be better than a puller fan?
Old Dec 8, 2013 | 01:34 AM
Usually the desire for a new radiator is based on the original one which over the years of owners failing to follow the owner manual - renew coolant every two years. So the use of non-distilled water has grown calcium in the lower rows, 24/7, and if you have the Dexcool and it has even minor contamination there can be the evil Dexmud. Testing the radiator top to bottom with an IR thermometer can show the fins are more than 10F cooler on the bottom, indicating less flow down there.
A new Nissens radiator, fresh fan clutch, working electric fan, and real Land Rover 180F thermostat. One member sent in this photo of a ride into the desert. Of course, if you have a head gasket or cracked block issue things can be a lot different. Worn out water pump also lowers cooling.
I live in an area with warm temps in summer, and I do like that my electric fans are on all the time with a D1, vs the D2 control system. I suppose one could wire a relay to bypass that and keep fan on at will. I also installed a non-stock fan on our water pump, with deeper pitch. Came from a 2000 Blazer, same screw threads. https://landroverforums.com/forum/ge...ghlight=Blazer More air flow thru radiator and cooler temps. 14-15 mpg in a D1 with AC on.
It gets pretty warm at Georgia Southern where my Disco lives during the week. Last week the college cafeteria had a special meal offering of Gator. To celebrate the Eagles victory over Florida.
Attached Thumbnails Better radiator... options?-bc8afb25-b563-4331-bdd7-c77d9c7f7685-8721-00000924dc11272f_zps3eba1104.jpg   Better radiator... options?-dex-cool-2.jpg   Better radiator... options?-p1030596.jpg   Better radiator... options?-p1120258.jpg
Old Dec 8, 2013 | 01:53 AM
dr. mordo's Avatar
That's very interesting that the D1 electric fan is on all the time. I've been thinking of wiring my electric fan to be switchable so I can run it constantly during the summer. It seems like the truck struggles a lot more to stay cool when ambient temps get over 90, and I figure more airflow can only help.
Does the D1 fan shut off at higher speeds, or it literally never shuts off?
Old Dec 8, 2013 | 02:02 AM
Always on, whenever AC is switched on.
