Big Plans This Weekend (Need Advice!)
Old 02-05-2021, 04:40 PM
Kuenzig's Avatar
Default Big Plans This Weekend (Need Advice!)
Alright everyone, need some screening and advice for everything I've got planned this weekend.
1. Coolant flush: Extinct's inline thermostat mod, refill with green coolant.
2. Replace valve cover gasket: (FEL-PRO, VS50789R).
3. Engine Oil change: 15W-40 Rotella T5 and Mobil 1-301 filter, new drain plug (British Parts Utah, LSF100040L) and washer (British Parts Utah, ALU1403L).
4. T-Case, front diff, and rear diff oil change: Vavoline 75W-90 Gear oil, new fill/drain plugs and O-rings. (British Parts Utah, TYB500120K & FTC5403BK).
5. Replace upper/lower ball joints and tie rod end: Upper (MOOG K500145), Lower (MOOG K500059), TRE (MOOG ES800783).
6. Replace Positive Crankcase Ventilation Valve: Brass (WVE, 6P1129).
7. Replace front driveshaft U-joints: (ACDELCO, 45U0168).
8. New spark plugs (NGK Iridium IX, 3764).
9. Transmission fluid, filter, and drain plug: Valvoline MaxLife, Eurospace Trans Filter Kit (EU-RTC4653K). Also got new bolts and spacers just in case.
10. Replace air filter: Bosch (BS-LR027408).
Not necessarily in that order.
I know it's a lot but I'm fortunate enough to have a good mechanic friend with a fully loaded shop who offered to help/teach me. The plan is to get in by about 7, bring beer and pizza and work our asses off.
Mainly looking for any advice or tips going into this. I'm also planning to record as much as I can for future enthusiasts to use in their endeavors as well.
Any and all help/criticism/recommendations are welcome and appreciated. Thanks in advance!
If you have questions please feel free to PM me as well.
Old 02-05-2021, 04:49 PM
mln01's Avatar
I need better friends.
The following 4 users liked this post by mln01:
cvhyatt (02-06-2021), greisinb (02-05-2021), jacobmstein (02-05-2021), Kuenzig (02-06-2021)
Old 02-05-2021, 04:55 PM
Alex_M's Avatar
Good luck with those ball joints, they're a real PITA. Double check the centering ball on the double cardon joint in the front driveshaft. That's part of what causes them to fail.
Tcase fluid is also a pain to change. If I recall correctly you've got to remove the parking brake drum to get at the fill(?) plug.
Old 02-05-2021, 04:59 PM
Kuenzig's Avatar
Thanks! I've been spraying them down as well as the fill/drain plugs with liquid wrench for the last 4 days. Hopefully that helps.
The Deputy (02-05-2021)
Old 02-05-2021, 05:48 PM
Kuenzig's Avatar
Luckily my job has the need for a mechanic shop and qualified technician. We just happened to have a lot of the same hobbies and get along well.
Old 02-05-2021, 07:44 PM
Best4x4's Avatar
Received 2,297 Likes on 1,688 Posts
Serpentine belt tool usually works great on the TC fill plug
The following 3 users liked this post by Best4x4:
Alex_M (02-06-2021), jastutte (02-06-2021), Kuenzig (02-06-2021)
Old 02-05-2021, 08:00 PM
escott16's Avatar
you do not need to remove anything for tcase fluid
Old 02-05-2021, 08:08 PM
Tcase fluid is very easy, wait until afternoon after a few beers for the joints. Beer = power
btw.
that’s one mean looking dog
Old 02-05-2021, 09:09 PM
JUKE179r's Avatar
Originally Posted by redwhitekat
Tcase fluid is very easy, wait until afternoon after a few joints.
Fixed that for you.
Old 02-05-2021, 09:12 PM
Kuenzig's Avatar
That's a great idea! Looks like I'll be taking a trip to Harbor Freight tomorrow. Thank you for this and all the other recommendations you made on my first post to get me here as well.
Quick Reply: Big Plans This Weekend (Need Advice!)
