biggest tyres to fit +2 lift
Old 11-23-2017, 07:14 AM
markdeg's Avatar
Default biggest tyres to fit +2 lift
so, my first of many questions. I will get my 'new' discovery 2 today and looking forward to start modding it a bit. First mod is obviously a +2" lift and new tyres. What would be the biggest tyres that could fit in without any further modifications?
Old 11-23-2017, 07:25 AM
Alex_M's Avatar
What size rims have you got?
Old 11-23-2017, 07:31 AM
markdeg's Avatar
it is on 18inch wheels but I am thinking of getting new smaller wheels, 16 inch probably.
Old 11-23-2017, 08:01 AM
Alex_M's Avatar
16s are probably your better bet if you plan to off road it.
265/75r16s are kinda the standard go to, though I never ran a 2" lift; jumped straight up to 3.5" with 285/75r16s. Someone who knows better can tell you more than I can.
Old 11-23-2017, 08:11 AM
The Deputy's Avatar
Received 1,167 Likes on 842 Posts
Default You may find some info in here...
https://landroverforums.com/forum/di...rements-56226/
Brian.
Old 11-23-2017, 08:19 AM
The Deputy's Avatar
I've got 2 inches of lift, 265/75's seem fine. No rubbing of any kind, granted...I've only done some mild wheeling so far. I've got about 20.5" from center of wheel to wheel well lip on front and 21" in rear. Have a winch, bush guard and small skid plate in front.
Wish I'd have gone with 285's, but I got a smoking deal on these 265's...so they will stay until wornout.
Brian.
Old 11-23-2017, 08:50 AM
markdeg's Avatar
Nice, what size of wheels do you have?
Old 11-23-2017, 08:55 AM
Best4x4's Avatar
Received 2,248 Likes on 1,667 Posts
255/70R18, 265/75R16 should work with zero rubbing. Also if you fit the 265's and have rubbing at full lock (more often in reverse) check your turn stops. Some D2's have short ones and some have longer ones. I personally did what I used to do with all my Jeeps = made custom length turn stops. On my 02 Kalahari I got new bolts and was able to find a collar that was the perfect length giving me the most turning radius without rubbing or sacrificing my turning radius. You could always just use washers to get the exact length as well. I got the new bolts at my local Ace Hardware Store.
You could probably run some 275/65R18's as well with some possible lower front bumper trimming.
Old 11-23-2017, 09:06 AM
markdeg's Avatar
wow, that is almost 32". Do you think I would need to change the transfer case to a 1.4 then? Are there any other components that need to be changed due to excessive wear?
Old 11-23-2017, 10:23 AM
Alex_M's Avatar
I run stock gears with my 33s and tow a lot with it. These engines make enough torque that you have to go a lot bigger to really need gears.
I'll be upgrading mine in the future, but not because it's strictly necessary. On 32s you'll be perfect.
Quick Reply: biggest tyres to fit +2 lift
