Bleed brakes with Hawkeye or similar
So I just bought a hawkeye. I was wondering if anyone had any instructions on how to use it to bleed the brakes on my Discovery 2? Do I just run the circuit test for the "hydraulics" for a particulare wheel, and then open the bleeder while the pump is running?
So far this tool seems pretty cool... (and it better for the price) but it is very lacking in instructions for the things that aren't obvious to me.
The main reason I'm asking is that I pulled the codes for my 3 amigos and the only code was 4114 for the shuttle valve. So I was going to do the repair in the stickies, but I figured I would just remove the whole assembly and then use it as a good time to replace all of the fluid and maybe the rubber brake lines too.
Thanks!
Thanks!
bballjames
12-22-2018 07:21 PM
99TEXASD2
11-07-2014 07:01 PM
