Bleed Screw...Screwed ME!
Old Jan 26, 2011 | 02:39 PM
jeffh's Avatar
Default Bleed Screw...Screwed ME!
It was in the end not that big of a deal...but! So the bleed screw on the coolant T decided to split in two in the woods and snow when it was 4 degrees and I was by myself. I had a few extra button head screws with me so i was able to extract the remaining piece and re-thread with a touch of Permex around the head for extra security..It has proved to be a good temp fix. Soooo, I would like to replace the entire T with a brass fitting not the LR factory plastic. Does anyone know of a parts house that might have this. Thanks. Sorry no pictures I was cold and pissed.
Old Jan 26, 2011 | 04:00 PM
nitefall's Avatar
you could try BMW, i got my new Bleed screw from them, it's brass. Don't know about the whole assembly though.
Old Jan 27, 2011 | 11:14 AM
Find a metal fab shop and have one made, cause no one makes one.
I would just suggest you go by BMW and buy a couple screws and be OK with it.
Old Jan 27, 2011 | 12:00 PM
FightOnUSC79's Avatar
What he said. The BMW screw is the way to go. Mine went and i had to seal it with jb weld to get her home.
Old Jan 27, 2011 | 01:10 PM
Alex J's Avatar
FYI from someone that works at a BMW shop, the OE BMW bleed screws are plastic. You will need to go to a shop that knows where to get the brass bleeder screws. If you can't find a local shop to get you the brass ones send me a PM, I can get them from one of my suppliers.
Old Jan 27, 2011 | 01:17 PM
DiscoIIBrandon's Avatar
LRForums.com group buy discount
Old Jan 27, 2011 | 02:02 PM
Alex J's Avatar
I think the only way my boss would OK that is if there was an order for probably 15-20 of them.
Old Jan 27, 2011 | 02:10 PM
Rover comes with the plastic screw, a metal one is not needed on the plastic tee, just put a little lube on the thread and don't tighten it so tight you can't remove it.
Old Jan 27, 2011 | 08:35 PM
Urban Panzer's Avatar
The plastic bleed screws are just as ****e as the diff fill plugs, brass ones are much better and yes somebody DOES make them
http://mrautomotive.com.au/index.php...d=21&Itemid=39
Old Jan 27, 2011 | 08:58 PM
Anyone in the states?
