bleeding coolant?
bleeding coolant?
I have read all about how to bleed the air out of coolant and It still has air in it. I try lifting the expansion tank every morning and it seems to be bled and when I drive it sounds of air in the heater core.I have done this with my other disco but this one is being stubborn. I have tried elevating the front and then try and I still cant get the air out. I recently changed the thermostat and flushed the heater core to get my heat back workin and it is, but just cant get the air out. Any suggestions thanks, Brent
Remove the cap from the overflow tank.
Idle the engine with the heater on until the engine reaches temp and then rev to 2000 rpm and hold it there for a few min.
Replace the cap and then shut it off.
Drive as normal and see if the sound goes away.
Are you loosing coolant?
If you have a leak you will never get rid of the noise.
