Bleeding the radiator
Old May 7, 2008 | 10:49 AM
herblatham's Avatar
Default Bleeding the radiator
Can someone tell me how to bleed the radiator? and how much coolant is supposed to be in the resevoir?
98 disco
123000 miles
Old May 7, 2008 | 12:13 PM
Landzu's Avatar
Default RE: Bleeding the radiator
You will see a plug on top of the radiator right side (battery side) on flat ground take that plug out and it will level off at what looks like a plus (+) sign its should be at the top of the plus cold.
The plus sign is in the resevoir if you look in it.
Old May 7, 2008 | 01:13 PM
Bleed the radiator thru the lower pet **** and make sure you bleed all the air from the radiaor by removing the top plug, filling the coolant bottle to the top then continue to fill the bottle till coolant comes out the top radiator plug.
Old May 7, 2008 | 02:16 PM
herblatham's Avatar
the "lower pet".... what's that? Thank you in advance for your patience in my apparent ignorance about this stuff
Old May 7, 2008 | 06:35 PM
Landzu's Avatar
Here are some Pic's
I do not have a radiator drain pet___ _(rooster) (other name)on my Disco I.
[IMG]local://upfiles/649/A8736321E4A04C698C47F6BF9E1403B0.jpg[/IMG]
[IMG]local://upfiles/649/E008665049C3460BB5A0087DF5D720C8.jpg[/IMG]
rancher43
May 18, 2010 05:55 PM
skewett
Jul 8, 2007 11:28 AM
Elhoff
May 29, 2007 11:13 AM
mdvickst
Apr 30, 2007 11:20 PM
mr.47
Sep 24, 2006 10:16 PM
