Blinking service engine soon light & vacuum leak
Old Nov 29, 2010 | 09:34 PM
landRoverNewbie's Avatar
Default Blinking service engine soon light & vacuum leak
Hello,
I have a 105k 2001 Disco II. The service engine light just came on and is blinking. I have the codes they are P0300, P0302, P0303,P1300, P1590.
I am attaching a picture of a hose that had a leak in it that I have electrician taped up until the a new hose is ordered. If someone can tell me what hose it is to order a new that would be great. I think the codes may be due to the SAI... Also the car starts fine but sounds like a muscle car when idle.
Any help is appreciated.
thanks
Attached Thumbnails Blinking service engine soon light & vacuum leak-landrovervalve.jpg   Blinking service engine soon light & vacuum leak-lr_2.jpg
Old Nov 29, 2010 | 09:46 PM
buick215's Avatar
Do you have any other lights on other than the blinking service engine light. The reason that I ask is because p1590 is an ABS related code and I don't believe it has anything to do with your engine.
Old Nov 29, 2010 | 10:56 PM
yes the three amigos are on but they are the least of my worries for now...
Old Nov 30, 2010 | 07:12 AM
Your leaking hose has nothing to do with your misfires on 2 and 3, when did you last do a tune up along with new 8 mm plug wires?
Old Nov 30, 2010 | 08:23 AM
thanks, what is the part number or a recommended brand for the wires. Also any idea's for what that hose is called that is leaking the air.
Old Nov 30, 2010 | 08:38 AM
hilltoppersx's Avatar
those pictures are tiny can't even see anything but dirt. i use magnecore 8mm wires from Apexperformance.net some people like hte kingsborne 8mm or the sti 8mm wires. get yourself some good plat plugs as well. i use bosch +4's some people liek the NGK's.
Old Nov 30, 2010 | 08:43 AM
souljad9's Avatar
That hose is lo longer available from land rover. I broke mine while doing my HG, and fixed it with some copper tubing. It's not pretty, but it works.
Old Nov 30, 2010 | 09:02 AM
wow I don't really access to copper piping do you have any suggestions for another type of hose since its no longer available
Old Nov 30, 2010 | 09:11 AM
Figure it out for your self. Cooper pipe is available at any hardware store as id good PVC piping, use your imagination.
As for the wires, go to British Parts of Utah and buy a set of 8mm STI wires for $70.
Old Nov 30, 2010 | 10:03 AM
souljad9's Avatar
You can buy 3/4" copper tube and 2 elbows at any hardware store, HD, Lowes, etc. PVC would probably work fine too, but I had a piece of copper at the house laying around. The copper fits into the rubber coupling at the hard pipe, and slips over the hard plastic corrugated tubing at the pump. little bit of right stuff, and some electrical tape, and your done. I may wrap the whole thing in wire loom or something to make it prettier.
As for plug wires, I used 8mm Kingsbourne wires, for $35.
http://www.kingsbornewires.com/produ...&categoryId=38
