Block pressure test? psi?
Old Jan 25, 2016 | 05:37 PM
Hephaestus's Avatar
Default Block pressure test? psi?
Hi all, I have a 2000 d2 with 177k. Tested positive for exhaust gases in coolant. I took the heads off yesterday and the gaskets looked OK. Nothing obvious. I set up a pressure test for the block and was wondering what psi I should charge it up to. Thanks!
Old Jan 25, 2016 | 09:30 PM
Hephaestus's Avatar
Found it 20 psi.
Old Jan 25, 2016 | 10:18 PM
Wilson7287's Avatar
Originally Posted by Hephaestus
Found it 20 psi.
How did you pressure test the block yourself??
Old Jan 26, 2016 | 12:50 AM
Hephaestus's Avatar
Just bolted some scrap metal and rubber over the coolant ports. Made one with an air fitting so I can hook up to a gauge and valve. No leaks, going to order gaskets and bolts tomorrow. Nothing to lose except time and money!
Old Jan 26, 2016 | 05:09 AM
Wilson7287's Avatar
That's awesome. Did you keep the water pump as is or have to block it off as well? What bolts did you use? If you have a picture that would be awesome of the plates / rubber.
Old Jan 26, 2016 | 05:53 AM
drowssap's Avatar
sorry about your block
Old Jan 26, 2016 | 09:12 AM
Hephaestus's Avatar
Drowssap, can you offer some insight?
Old Jan 26, 2016 | 10:02 AM
drowssap's Avatar
either install flanged liners or replace the block are your options. where are you located?
Old Jan 26, 2016 | 10:11 AM
Hephaestus's Avatar
I'm in Seattle. The block held pressure and passed the soapy water test. Did you have a similar experience?
Old Jan 26, 2016 | 10:21 AM
drowssap's Avatar
im a little confused, I thought you said you found the leak at 20 psi? where was the leak?
