Blower Motor Stopped Working, Started Working, then Stopped Working?
Old Feb 8, 2011 | 07:09 AM
tee51397's Avatar
No, you can just hook it up directly and you'll be fine.
Old Jun 19, 2017 | 12:38 PM
Vai2kdna77's Avatar
I think I am having the same issue. Where is the blower motor resistor located exactly? With the car turned over, I can hear the click when I press the AC/ Heater power button, but nothing comes on but the illumination portion of the control panel. I checked fuses, and I don't think it is the blower motor. Any other ideas? How can I check if it is the resistor that is the problem?
Old Jun 19, 2017 | 06:14 PM
LR03NJ's Avatar
turn a/c on, go passenger side and reach under near blower touching and moving wires little by little. Blower fan wires often get loose, it gets really hot when connections are weak. Well, you can also strat by testing the fan directly. Also, check the fuse box in engine compartment. If all fuse are ok, turn a/c on and press on the fuse box down with your palm touching most of the fuse and check if the fan turns on. Mostly the front part of the fuse box. The interface between the fuse box might not getting any contact very good.
Old Jun 20, 2017 | 03:35 PM
Vai2kdna77's Avatar
I have read about the Blower Motor Resistor going bad as well. How can I test this?
Old Jun 20, 2017 | 05:14 PM
disc oh no's Avatar
Usually the resistor is for the lower speeds. Full speed is often run directly through a fused circuit. If it doesn't work on any speed, check the fan by removing the connector and jumping power and ground directly to the fan.
Old Jun 20, 2017 | 07:16 PM
Mskembo's Avatar
'99 D2 owner here. Mine was from a loose connection at the motor. I got in there and soldered the connection and it's been good for almost a year.
Old Jun 21, 2017 | 07:11 AM
Vai2kdna77's Avatar
Well I put my meter on it last night, and when the power button is engaged there is juice going to it, but the fan is non responsive. Looks like I am going to be replacing the blower motor on this thing. Thank you all!
Old Jun 22, 2017 | 08:09 AM
Vai2kdna77's Avatar
YAY!! RESOLVED! I replaced the blower motor and it is super powerful now! Thank you for all of your contributions and help!
Old Jul 16, 2019 | 02:51 PM
Rdhilaire's Avatar
Default blower motor
Thank you. I read the threads but didnt find one where it was working fine, stopped for a few days, then started back and ran for several months then stopped again all together.
I had the same problem/do have the same problem. It seems to be the blue plug that powers the motor. Squeeze it and it starts to blow. I'll eventually pull it out and wire it hard. Usually a good wack under the glovebox starts it up.
Old Jul 31, 2020 | 01:42 AM
jodyru's Avatar
3rd Gear
I replaced Everything on my 99 and still nothing....Till I came opon this vid,did evrything in the vid and it worked..Here is the vid
