Blower resistor
Old Feb 14, 2016 | 05:54 AM
batard's Avatar
Default Blower resistor
Atlantic British recently put up an interesting video on replacing the blower motor resistor:
My blower is ok, but I feel the power is kind of weak, even on full blast. It seems like it should be stronger. Anyone think it'd be a good idea to replace this in an attempt to fix? The genuine part is a bit on the pricey side. Resistor - Climate Control Blower Motor (Genuine Part # JGN100011 ) - Land Rover connector\relays\flasher from Atlantic British
Old Feb 14, 2016 | 11:26 PM
PalmettoDisco's Avatar
At full blast the resistor is bypassed completely. The blower has another known issue with the solder cracking inside the passenger fuse box/block. Typically the problem is intermittent power. Possibly you have a loss of amperage from this typical problem. I would try supplying direct 12v power to the blower and see if it performs better. Also, there may be trash inside impeding its performance.
Old Feb 15, 2016 | 08:42 PM
Joemamma1954's Avatar
I had same problem, and I pulled the blower motor and it was packed full of leaves. Now it blows like it should.
mirepoixmatt
Jun 19, 2016 02:02 PM
cableguy1979
Oct 18, 2015 04:42 PM
4thefamily
Jul 1, 2015 09:17 AM
ezikial4
Jun 28, 2009 08:23 PM
Ali
Jan 23, 2008 05:52 PM
