Blown Head Gasket?
Old Jun 9, 2022 | 01:12 PM
Extinct's Avatar
I've seen worse, looks like you had a couple of external leaks.
Old Jun 9, 2022 | 06:21 PM
Troy_Less's Avatar
Extinct, thanks for the reply. Could you please note exactly where you see the external leaks? By external, I presume you mean combustion gases to the atmosphere... not the coolant system. Or maybe coolant leaks to the atmosphere? Thanks!
Old Jun 9, 2022 | 06:56 PM
Richard Gallant's Avatar
Looks to me like you got some seepage on the drive side rear piston, based on the white on the piston and valve. Looks to me like just a bit of steam cleaning. If you look at your driver side photos the one valve is a lot cleaner than the rest,as is the matching piston.
I could be wrong not an expert here but that is what it looks like to me
Old Jun 9, 2022 | 07:09 PM
Extinct's Avatar
I don't think you have any steam cleaning, but here is what I saw as external leakage.
Old Jun 9, 2022 | 07:21 PM
@Extinct That valve by the external leak looked very clean to me compared to the rest.
Old Jun 9, 2022 | 07:33 PM
Extinct's Avatar
Looked to me like that cylinder was running just a bit lean, exhaust valves typically are colored by the fuel mixture.
Old Jun 10, 2022 | 08:41 AM
Troy_Less's Avatar
Thanks, Extinct and Richard Gallant. I'm checking the block and was wondering what size feeler gauge to use. Lowest I had was a .004", but read on this forum to use a .002 for the heads. I presume the same for the block? .002 is a good bit smaller than I'm used to using.
Old Jun 10, 2022 | 12:12 PM
@Troy_Less from another source
from new RR says the reface limit = 0.50mm (0.02 in) from new dimension.
To check the new dimension (cylinder head at each end)
Engine numbers without suffix B
A = the lower part of the head = 23.9mm (0.94 in) Where the head bolts are)
B = the upper part of the head = 63.5mm
Engine numbers with suffix B
A = 22.94mm (0.903 in)
B = 65.56mm (2.463 in)
You can check if the head is warped with a very good straight edge.
for warping. across centre and from corner to corner.
Max warp = 0.05 mm (0.002 in)
Have you done this sort of work before? there are lots of things to consider..
Old Jun 10, 2022 | 12:35 PM
Harvlr's Avatar
Feeler gauges that go to .0015” are quite common and easily obtainable.
Old Jun 10, 2022 | 01:46 PM
Troy_Less's Avatar
Harvlr, thanks for the response. I got a set that goes down to .015 yesterday. Thanks.
