Blown head gasket - sounds like exhaust leak - Block damage?
Old Jun 22, 2014 | 06:45 PM
abnormals_anonymous's Avatar
Originally Posted by dr. mordo
I'm not sure what you're saying here, but a cracked exhaust manifold or a blown exhaust manifold gasket (if present) will also cause 'tooting'.
Merely laughing at Dusty's comment as I have an issue on my DII that I'm trying to analyze and it obviously isn't a 'running toot' sound. Therefore I don't think my issue is exhaust related. What did you think I was implying?
Pete
Old Jun 22, 2014 | 07:24 PM
dr. mordo's Avatar
I got you confused with the original poster. So I thought you had the tooting but for some reason concluded it wasn't exhaust related.
I'd been drinking.
I agree "the jogging toots" is a pretty funny description. Also not a terrible band name. Ok, maybe it is a terrible band name.
What is your noise?
Old Jun 23, 2014 | 07:16 AM
drowssap's Avatar
hold a rag over the exhaust tip, if it is an exhaust leak you will hear the back pressure coming out.
Old Aug 18, 2014 | 01:42 PM
Ok, so maybe I spoke too soon. My rig doesn't sound like the video but my SES light came on over the weekend. Read codes and got the infamous P0455. Noticed that there was a crack in the gas cap seal, changed it out and still have the SES light. Does it go out or do I have to reset the codes?
I'll put a rag over the exhaust tonight and see if I can determine if it's leaking anywhere along the line.
My noise was more of an 'airy' noise - hard to explain - like she doesn't have the guts she used to. Not transmission sounding but more of a roar. I know that sound strange... but then again, I'm not normal.
Old Sep 9, 2015 | 09:45 PM
TT&I's Avatar
Originally Posted by jfall
Sooner you fix it - less damage will happen.
worst case is head needs decked and the block may need decked.
Decking a block is expensive.
So, just replace the head gasket now and see how it turns out.
I was told by a Rover shop that if on exhaust side of engine the "puff puff" leak due to head gasket leak will not cause damage. It might get louder and needs to be changed but no fear of damage should exist. Its more of an annoyance. If it was on coolant side of engine that would be different.
I was told I could get another 2000 miles easy. Head gasket job with a few xtras like new valve stems and cleaning etc while the engine is broken down will run around $1500.
Old Sep 10, 2015 | 07:25 AM
drowssap's Avatar
the temperature of the exhaust gases escaping will eventually damage the head or block. the heat and pressure can eventually cut a groove in the aluminum.
Old Sep 10, 2015 | 09:53 AM
Extinct's Avatar
Agreed, it is more dangerous than you think to long term damage. The escaping air will also continue to damage the head gasket, and could eventually cause a coolant leak. Better to get to it now than wait. Headgaskets only should be all that is required. I did my daughters with 200k on it and she is still running strong.
Washington Rover
Jan 12, 2014 08:10 PM
MoShadeTree
Dec 31, 2012 07:32 PM
4x4ron
Sep 3, 2012 09:57 PM
jrm123180
Feb 2, 2012 12:09 PM
doomed
Dec 30, 2010 12:11 AM
