Bolt specs for rear spring mounts?
Installing heated seats in a Disco S and rear spring plate bolt sizes.
I looked in the RAVE and I couldn't find anything. I'm making some 2.5" polyurethane spacers to go under the rear spring plates and I need to order some replacement bolts. What is the specs for the factory bolts so I know what to get to replace them.
Completely unrelated, but I didn't want to make two threads at once. I read that all D2s fitted with leather seats have the heating elements and working built in for heated seats, just no plug. My '04 SE parts truck has leather seats, but no plugs behind the window switch panel. There is, however, a green plug behind the panel on both the '04 parts truck and my '03 'S model. I'm curious what that is. I hooked a switch up to it and turned it on, but nothing seemed to happen. Any ideas?
Update: I found the black plug, so I took an extra HDC and Emergency Blinker plug that I had, trimmed down the little ridges, and hooked them in. I turned them on for a few minutes and nothing seemed to heat up. Are the buttons different or will I have to move the seats from the SE truck and just have the upholstery switched? (the leather is tan and I have black)
Update 2: I watched the Rovers North video. It says to check for the module under the seat. I checked and it's there, fuses under the seat are fine, everything is hooked up. Any ideas?
Also, is there any way a mod could rename this thread for those looking for heated seat info in the future?
