Bolt / thread size for heater pipe to intake
Old Jun 16, 2022 | 12:32 PM
girlfriendboughtarover's Avatar
Default Bolt / thread size for heater pipe to intake
EDIT: Solved!
Re: the post below ... The bolt is an M8 x 1.25 standard, and I bought a pretty short one. No need to go long.
Hey all,
I am putting the finishing touches on a Disco 2 head gasket replacement. I am wondering if anyone knows the bolt size / thread for the bolt that secures the heater pipe to the lower intake manifold.
I have a bolt that seems to go in half way then has a lot of resistance and I think the threads may be messed up. So may have to re-tap. Just want size and threads to make sure, if anyone knows.
I know securing this pipe is pretty important. Replaced the O-ring on it.
Thanks
Last edited by girlfriendboughtarover; Jun 16, 2022 at 06:04 PM. Reason: Solved issue
Old Jun 16, 2022 | 06:08 PM
Default Solved -- needed to re-tap threads
Hammered on a socket to the 8mm x 1.25 tap because the handle wouldn't fit in the space. If I had the rocker cover and upper intake off, it would be doable with the tap handle. Thankful to the Rover gods that I didn't need to heli-coil it.
Francopacks
Feb 15, 2023 07:08 PM
CanadianRover
Jun 15, 2022 05:35 PM
Wachy
Nov 10, 2014 04:03 PM
jpmiller
Jan 22, 2012 12:59 PM
wyrdvans
Nov 1, 2011 11:01 PM
