Bosch +2
Old Sep 27, 2008 | 07:28 PM
theworks001's Avatar
Default Bosch +2
Are the Bosch +2 spark plugs good I've read about the +4, but are the +2 ok, are they better thank stock??
also you don't gap them right??
can my stock wires work?? or do I need others
thanks
Old Sep 27, 2008 | 08:13 PM
Default RE: Bosch +2
When doing plugs it is best to do wires too.
Your stock wires will work with any spark plug.
The +2 is better than a standard plug.
I used Denso Iridium spark plugs.
Old Sep 27, 2008 | 08:55 PM
Jupiter Rover's Avatar
I use Magnacore 8mm wires and Bosch Fusions.. Awesome set up..
Old Sep 27, 2008 | 11:33 PM
Switzer's Avatar
I used Bosch +2 with good results until my factory wires gave out on me. In my desperation to fix the misfires I replaced the wires with Magnecor 8mm's and the +2's with factory Champions. I know now the wires were causing the problem and not the plugs. I plan to switch back to the +2 plugs tomorrow. The engine ran smoother with those plugs.
Cheers,
Pete
Old Sep 28, 2008 | 08:19 AM
I run thje 8 mm Magnacor wire, a real must, I put 65,000 on some Plus 4's with great results and then switched to the Fusions, the jury is still out on the Fusions. They work well, I just don't know if they are worth the extra over the Plus 4's.
Old Sep 29, 2008 | 07:57 AM
Landzu's Avatar
I have used Bosch +4's and found that in my Disco I they fouled out.
So I use the OEM Champion RN12YC,,,,at a $1.50 its the only thing cheap on
a Rover.
Old Sep 29, 2008 | 10:09 AM
Landzu,
Did you instyall Mahnacor wires when installing the Plus 4's? If not that was your problem, they need that extra voltage the factory wires can't give.
Old Sep 29, 2008 | 10:29 AM
Landzu's Avatar
I have used Magnacores for years before that I have used OEM wires.
The electrode on the +4's is so small that on a Disco I(mine) any carbon can
impair the plug.
Before that I had used OEM plugs or Champion's.
I had the Bosch +4's in for about a year then I had one foul bad,,,it gave no
warning.
They are not bad,, but I could tell no difference from the Champions to the Bosch
so for the money I can change the Champion out every year and keep the motor
running top notch.
Old Sep 29, 2008 | 10:43 AM
NiteTrain's Avatar
I just installed Magnacor 8mm wires and now I'm trying to decide which plugs to run, currently has bosch platinums in there. My opinion of any 4 electrode plug is that they have a 1 in 4 chance of being in the 'sweet spot' position and a 1 in 4 chance each firing cycle the spark will jump in that position since electricity follows the path of least resistance.
Old Sep 29, 2008 | 11:14 AM
Landzu's Avatar
Yes that looks like it would work,,,,,,,,,,until you
look at the eletrode its the size of a pin head and thats the part that
fouled out on mine.
