Bosch +2
Old Sep 29, 2008 | 01:46 PM
Switzer's Avatar
Default RE: Bosch +2
I swapped my Bosch +2's in this weekend and noticed it running smoother than with the Champions. Your results may vary. If carbon buildup is a worry just be sure to use top quality petrol.
Cheers,
Pete
Old Sep 29, 2008 | 03:19 PM
Landzu's Avatar
Disco I's not Disco II's. I was under the impression that Disco II's
came with Bosch plugs OEM if thats the case then it will run better
or your plugs where needing replacing before now.
Old Jul 18, 2011 | 02:00 PM
Lava Lizard's Avatar
Disco Mike... I am very new to this site but I have found info to be very helpful.
I have an issue with My Disco, she's an 02 with 98000 miles and we had a cylinder #7 misfire code come up last week
We took her to Autozone to get the read out and I figured I just replace the plug... Well I drove her after I did the switch and 20 min or so into the ride she got sluggish and the SES light began to flash.
Im not a mechanic but I like to do what i can if I am able to. I don't want to impose but could you give a tip on what else could be the issue
Thanks
Old Jul 18, 2011 | 02:31 PM
buick215's Avatar
My 2000 Disco II came from the factory with champion plugs and currently has champion plugs with 16,000 miles and no problems, codes, or warning lights.
LandRoverSE
Engine & Internal
20
Oct 20, 2012 08:14 AM
sledmaker
Jul 3, 2007 08:05 PM
v35atc
Dec 30, 2006 01:37 AM
rinmud
Feb 7, 2006 07:09 PM
dkdirt63
Apr 17, 2005 11:05 PM
