Bosch O2 sensor ?
Old Mar 27, 2010 | 05:26 PM
Jaymce's Avatar
Default Bosch O2 sensor ?
Just got 4 Bosch O2 sensors (part # 13927) plug ends are different. Upon looking on line I see 2 types of ends. Are these the wrong sensors or are there different ends? These will fit but do not clip in. Does anyone have the correct part # for the Bosch O2 sensors?
Old Mar 27, 2010 | 07:16 PM
greenwade's Avatar
O.o i am glad that I saw this before i ordered mine. When disconnecting the sensor from the wiring harness on the driver side pre cat O2, is it easier to go up from below the rover or down through the open hood?
Old Mar 27, 2010 | 07:20 PM
hilltoppersx's Avatar
what are you driving? a D1 or a D2?
Old Mar 28, 2010 | 04:56 AM
Jaymce's Avatar
97 d1
Old Mar 28, 2010 | 07:20 AM
in 97 D1's the O2's are vin specific. if the vin falls before VA350102 its one type of connector if its after and has Advanced Evaporative Loss (AEL) then its a different connector. where does ur vin fall?
Old Mar 28, 2010 | 12:50 PM
oljohnboy's Avatar
Havent I heard that you slice the bosch sensors on?
Old Mar 29, 2010 | 11:14 AM
Jaymce's Avatar
VA556100 so it is after and I assume the AEL system then?
Old Mar 29, 2010 | 12:13 PM
yes you have AEL. so now check to make sure the O2's you have are for AEL, my guess is they are not and thats why the connector seems to be wrong.
Old Mar 29, 2010 | 09:36 PM
PalmettoDisco's Avatar
"Havent I heard that you slice the bosch sensors on?"
That is for UNIVERSAL o2 sensors (Bosch or otherwise). You still need to know how many number of wires when using unis.
Old Apr 5, 2010 | 09:53 AM
Jaymce's Avatar
I sent the sensors back. I do not know if the part # 13927 is for the AEL System. I have the old sensor out and it has a part # of SAGEM 04LS001 and below that is NTK Japan 4LS. I did a search for the NTK 04LS001 and found a site that said it was the same as Nissan Part # 22690-85E10.
I still have no idea what the proper Bosch cross # is in this case. If it is the 13927 then the connectors must be spliced etc. and I am not about to do that. If I wanted to splice connectors I would have bought some cheap universal ones and started banging my head against a wall.
