Both Low Beam Lights out.
Old Nov 26, 2021 | 03:39 PM
cybercop's Avatar
Default Both Low Beam Lights out.
Checked fuses 9 and 10 in the passenger compartment fuse box, and I have power there with good fuses.
Can it still be the fuse stalk if that is the case?
When my daughter first reported the issue, I met with her and a all the lights on the console were lit up. Limping her home, the low beams would keep coming and going. Now I have no warning lights on the console, all fuses look good, but no low beams.
Any ideas?
Old Nov 26, 2021 | 08:33 PM
The_OGCJR's Avatar
Can you verify the battery and its connections are good? You may have already checked that
Old Nov 26, 2021 | 08:36 PM
The_OGCJR's Avatar
After that, check the plugs for the back of the headlight bulbs. I’ve had one corrode and cause intermittent operation on driver side headlight.
then, if that’s good…sounds like there is a weak ground somewhere
Old Nov 27, 2021 | 10:40 AM
cybercop's Avatar
yep, already checked.
Old Nov 27, 2021 | 10:41 AM
cybercop's Avatar
I'm do not think they would go at the same time if it is a corrosion issue.
Do you know what wires are low beam?
Old Nov 27, 2021 | 08:18 PM
O_Drizzle's Avatar
could be chewed wires. Maybe a rat got in. I would get the wire diagram off of google and just follow the wires back.
Kinz384
Feb 25, 2025 06:08 PM
sbquality
Sep 14, 2021 09:18 PM
andrewhalliday
LR4
Jun 27, 2016 10:04 AM
JamesDisco97
Aug 11, 2013 09:28 AM
Joshman
Oct 9, 2012 12:10 PM
