Bought an 03 D2. Where do I Start?
Welcome!
You need to start with and ELM 327 Bluetooth scantool off of Amazon and an Android phone with the Torque app. With that you can look at your 02 sensors to see if they are cycling. Look at the charts - post up the results.
1 and 8 are on different coils, so it might be just wires or just coils. Wires are a good place to start, coils usually drop cylinders in pairs per top and bottom pairs here:
All your 02 problems are on one side - misfire problem could be the chicken or the egg. Once you can scan the 02 you can determine if they are dead or the misfire is causing them to report dead. Watch your coolant level closely, the number one cause for 02 sensor failure is drinking antifreeze due to blown head gasket.
Also, I use more parts than most (fleet of 5 currently) and I buy the cheapest available, usually RockAuto. Don't find that much difference in quality from expensive parts.
I just got done doing some more peeking around and the spark plugs do look fairly new and it has STI wires. I suppose I should replace them anyways but I wanted to put photos up first to see if you guys agree.
Also I have not seen any smoke out the exhaust and the exhaust smells like normal exhaust. But I know these are not the tell all signs of blown head gaskets. Let me know what you think of these pics. Thanks for all your help.
Looks like you got lucky on the wires and plugs.
Check all of the plugs, Do the plugs in the misfiring cylinders look different/wet?
If so, you'll want to get a cheap usb boroscope to attach to your phone and then look into the cylinders for signs of coolant.
I'm near the Ballard Bridge on the S. side of the ship canal. Might as well do the misting with the water bottle in the dark test just to verify the veracity of the wires... lite mist from a plant type watering bottle... engine running hood open, dark outside, look for sparks when you spray.
vscott71
05-26-2010 06:47 PM
