Help please - rough idle, shudder & lots of codes
Old Mar 12, 2013 | 05:57 PM
j.dstasio's Avatar
Default Help please - rough idle, shudder & lots of codes
Hi everyone,
I'm having some problems out of one of my Discos. Here is some background:
1999 D2 159k, had a CEL for the bank one front 02 sensor. I replaced the 02 sensor. A few weeks later I noticed the truck was running a little rough, but no codes were present at first, then the 02 sensor code came back. I reset the code & over the next couple of days the rough running got rougher, louder & now the truck sort of shudders occasionally. I was overdue for plugs & wires so I replaced those this past weekend. Didn't seem to make any improvement. Here are the codes I pulled tonight:
P0130 02 Circuit Bank 1, Sensor 1
P0455 Evap Emission System Leak Detected (gross leak, no flow)
P0150 02 Circuit Bank 2, Sensor 1
P0174 System Too Lean (bank 2)
P1174 Lambda Control Adaption fault Bank 2. Last occurrence - maximum signal
P1300 Catalyst damaging misfire multiple cylinders. Drive cyclec: signal out of range - above maximum
P0308 Cylinder 8 Misfire detected
I am at a loss on where to start. Ideas?
Thanks guys!
Old Mar 12, 2013 | 07:19 PM
jfall's Avatar
Replace the two front O2 sensors.
Replace the gas cap.
Reset and erase all codes and see what comes back if any.
For difficult codes use
http://enginecodemaster.com
Old Mar 14, 2013 | 08:54 AM
j.dstasio's Avatar
Will do. Thanks for the advice. Any idea what would cause the o2 sensors to fail in a short period of time?
I have a more pressing issue as of this morning (water pump) so it looks like I'll have a bigger order to AB than I'd planned.
Old Mar 14, 2013 | 12:24 PM
Hold on that, the gas cap is not causing this.
Buy 2 front 02 sensors from BPoU or Atlantic British, install them, clear the codes and see what comes back.
Old Mar 14, 2013 | 12:28 PM
j.dstasio's Avatar
Any idea what's causing the o2 sensors to fail?
I replaced the bank 1 upstream sensor not too long ago I'd say less than three months ago. Was just replacing one side a bad call?
dillhole
Feb 20, 2020 02:30 PM
pedro_malo
Jan 14, 2012 08:30 AM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
aircraftguy
Jul 16, 2009 12:50 PM
eriqcharlz
Jul 3, 2007 09:30 AM
