Bought 2001 Disco :-)
Old Mar 23, 2015 | 10:59 AM
kwhelchel's Avatar
6th Gear
Default Bought 2001 Disco :-)
well we found a 2001 disco and picked it up :-)
work that has been done on it already :-)
new gaskets on head and exhaust manifold
New battery
New alternator
New starter
New power steering pump and lines
And fairly new tires
and recent state inspection
and he had the frame checked and fixed where needed.
And I have all the receipts of work done and parts too
Cons so far after a few days
3 amigos showed up after breaks started squeaking
headliner sagging
1 ignition key and ignition key on column a bit worn
rear jump seats levers stick
drivers side heated seat not working it seems
and engine oil dipstick needs to be replaced but have new one for it
paid 3k for it up here in Maine
with the work that has been done and from what I have read so far we figured it was not bad of a price. The 3 amigos where not present when I looked at 3 different times. but is now after we drove it a bit hard the past few days :-)
And we really really love it even if we need to put a few more bucks into it.
Just need to get a code reader for it now :-)
but with all the post about it I ma confused as too which ones really work and such.
But we very happy
Keith
Old Mar 23, 2015 | 11:32 AM
drowssap's Avatar
iCarsoft i930 this scanner not only reads & clears DTCs, but also reads and clears ABS and SRS. on line about $130.00.
There are many different scanners around even bootleg stuff but that usually requires a computer to run.
i see your in Maine try Zach at RoversNorth
Old Mar 23, 2015 | 12:02 PM
kwhelchel's Avatar
6th Gear
Thanks for the Info and I will look at it ;-)
johnkbl
Jan 19, 2010 05:22 AM
brentmiller
Dec 12, 2006 08:22 PM
Justmealex
Oct 19, 2006 06:45 PM
