Bought This.
Old Oct 30, 2014 | 08:12 AM
gribur's Avatar
Default Bought This.
I picked up this oil as it looked perfect but am still wondering if the Rotella 5w-40 synth would be better. I am in Ontario Canada so the cold months are upon us. Anyways here is what I bought. Castrol Edge with syntec 5W-50 full synthetic. It says meant for older cars , high Zinc content especially suited for older flat tappet engines. api service SN,SM,SL. TY for any help, currently has rotela dino 15-40 put that in to give it a bit of a cleaning cycle. cheers all, be safe and hope to hear from you.
Old Oct 30, 2014 | 10:19 AM
Alex_M's Avatar
I've never used the stuff personally, but I've run the rotella 15w40 in 0 degree (Fahrenheit) weather with no issue. I personally prefer to stick with what I know works, I'd guess the Castro still has a lower zinc content.
Old Oct 30, 2014 | 12:46 PM
sdhow's Avatar
I've tried three different oils recently, in an effort to evaluate oil pressure subsequent to the oil pump replacement:
-Mobil 1 15W50 Racing Oil (synthetic)
-Kendall 20W50 GT-1 High Perf Oil (semi-synthetic)
-Shell Rotella T 15W40 (non-synthetic)
Now, I'm not in a "cold" weather environment (Central Calif.), but all seem to perform about the same wrt oil pressure and contain higher levels (1200 ppm) of ZDDP; I'm hoping the Rotella will help out with top end component cleaning.
Old Oct 30, 2014 | 01:00 PM
CollieRover's Avatar
I don't know anything about the oil you just got, but I received this info with my Turner Short block so I stick with Rotella.
Attached Thumbnails Bought This.-oil-info-001.jpg   Bought This.-oil-info-002.jpg
Old Oct 30, 2014 | 02:02 PM
sdhow's Avatar
In addition to the Comp Cams break-in oil referred to in the Turner doc, Lucas makes one, too, and it's readily available at most O'Reilly's Auto Parts stores.
Old Oct 30, 2014 | 02:53 PM
Alex_M's Avatar
The Amsoil break in oil is also available at most O'Reilly's. Comes down to preference I guess, that's what they recommended to me.
Old Oct 31, 2014 | 05:38 AM
drowssap's Avatar
interesting read, i guess Turner would know
Old Oct 31, 2014 | 09:37 AM
SDinDS's Avatar
If the oil you use doesn't have zddp then just add it:
ZDDPlus | Maintain proper ZDDP levels in your engine
Loose_Screws
Jul 19, 2005 06:31 PM
beavis4g63t
Jul 14, 2005 12:02 AM
nick1996rover
Feb 11, 2005 05:03 AM
Benhamtroll
Dec 14, 2004 03:55 AM
tscheinoha
Nov 18, 2004 02:19 PM
