Bought a large roof rack, how do i mount it now?
Old May 10, 2014 | 10:57 PM
Jared9220's Avatar
I have the rack off the truck right now so it might be hard to tell how it mounts but here are some close ups.
Bought a large roof rack, how do i mount it now?-20140510_224852.jpgBought a large roof rack, how do i mount it now?-20140510_225026.jpg
ls1morethanyou's Avatar
Good to see you are making progress! As for "thicker stock" on the brackets, that's a big YES if you plan on putting any real weight on the rack.
And for as little as it will cost, you might also want to add another set of brackets at the A Pillar.
Good luck!
yes, doing 4 per side and i am making the bend longer as well. tomorrow will be fun!
Thanks again for the suggestion.
Old May 10, 2014 | 11:38 PM
Rover_Hokie's Avatar
^^^ X2, 4 mounting brackets each side is the way to go
Old May 12, 2014 | 12:22 PM
Attempt number 2 on bracket making.
Old May 12, 2014 | 01:41 PM
Here is where i am at now. 8 L brackets, 11 inches tall and 5 inches in length on the bend.
doing math on the holding bracket and the anchor point.
Old May 13, 2014 | 08:39 AM
drowssap's Avatar
I believe you want the brackets under the basket pushing the weight up, rather than on top of the basket holding the weight from going down.
Old May 13, 2014 | 11:24 AM
But wouldn't that give me more down force?
Those are just mock setups to visualize what io am doing and to take measurements.
here are the brackets i made, now they arent pretty but they will work.
once i have help i will tack weld the feet then align as needed, add another tack weld, remove from truck and prep/weld paint- drill holes and mount.
Old May 13, 2014 | 01:27 PM
Dane!'s Avatar
how much did you buy that thing for? Just curious.
Old May 13, 2014 | 02:41 PM
primussucks's Avatar
just curious... why did you have the front come out so far over the windshield?
have you had it on the highway yet? what is the noise like?
Old May 13, 2014 | 03:55 PM
$125 and ive spent 100 on materials for the brackets.
i have not welded on the brackets so it hasnt been driven on.
its in the mock up phase so the rack will be moved back/forth and side to side some once i am ready to weld.
