Brake Bleed Day
Old Jun 27, 2015 | 10:26 AM
MPDano's Avatar
Default Brake Bleed Day
After reviewing RAVE, the sequence is as follows on the diagram.
Old Jun 27, 2015 | 10:28 AM
MPDano's Avatar
Brake Fluid Type:
Old Jun 27, 2015 | 10:29 AM
MPDano's Avatar
Brake Bleeding Procedure:
Old Jun 27, 2015 | 11:14 AM
MPDano's Avatar
What Dot 4 Fluid are you guys using? Is synthetic ok? Brands?
Basically gonna flush the system out with new. Might as well do it right and ask you guys.
Old Jun 27, 2015 | 01:01 PM
MPDano's Avatar
Decided to go with this Pentosin stuff. Dot 4 non synthetic low vis from Europe. Pricey stuff but should be good to go. Most of the stuff at Pep Boys was Dot 3 or Dot 3/4 Synthetic. Ran out of time to do this today as I had to replace one of my rear seat belt mechanisms and now gotta do family stuff.
Will post pics of my process manana.
Attached Thumbnails Brake Bleed Day-20150627_105425.jpg   Brake Bleed Day-20150627_105437.jpg   Brake Bleed Day-20150627_105449.jpg
Old Jun 27, 2015 | 01:05 PM
abran's Avatar
^ I use that stuff, it has German writing on it so it must be good.
Old Jun 27, 2015 | 01:07 PM
MPDano's Avatar
Ha ha, I was thinking the same. European car, European Fluid. That plus they didn't have any true Dot 4 non Synthetic besides this stuff.
Old Jun 27, 2015 | 01:31 PM
OffroadFrance's Avatar
Read on the small print 'says Made in China'
Old Jun 27, 2015 | 01:48 PM
MPDano's Avatar
Funny as all I see is big block letters that say "MADE IN GERMANY."
Old Jun 27, 2015 | 02:01 PM
claudio413's Avatar
I use Autozone house brand DOT 4, $7 a quart, rated to 475 degrees. It's awesome.
