Brake bleed leads to three amigos?
I had my brakes bled (and tires rotated/balanced) by an indy shop last week. About 40 miles later, I get the three amigos. ABS amigo says the codeis: front left sensor bad output (once it was low output).
Before I try to fix this myself or take the car back to the shop, I wanted to know if they could've loosened (or otherwise messed up) the abs sensor's connection into the hub when they did the brake bleed.
I've never done much stuff with brakes before...sorry if this is a dumb question. I just find it curious that I get the bad sensor output right after a brake bleed. I've cleared it and it comes back rather quickly every time.
Does the cable just pull straight out of the connector? Maybe I should disconnect the cable, clean, then reconnect?
mx468
Dec 20, 2015 10:47 AM
ls1morethanyou
Sep 7, 2014 03:13 AM
A boy and his Disco
Aug 30, 2013 05:59 PM
