Brake Bleeder
Old Jan 15, 2009 | 07:44 PM
AK Rover's Avatar
Default Brake Bleeder
I have been looking for a good way to bleed the brakes alone and found this Motive Products Brake Bleeder setup.
http://store.summitracing.com/partde...5&autoview=sku
Just curious if anyone has used this setup and how well it worked. I'm actually looking at the model with the aluminum fittings rather than plastic but this should give you guys the idea.
Old Jan 15, 2009 | 07:46 PM
tomfraser's Avatar
Default RE: Brake Bleeder
I got the 4.99 bleeder kit from autozone
has a magnet and a bottle that connects to the bleeder
go in car, pump brakes to move fluid
it worked great, so 50 bucks for a brake bleeder might be more than someone who won't do it very often needs
Old Jan 15, 2009 | 08:04 PM
jkid's Avatar
Ditto, I've always had good luck with the cheap advance auto kit. I'm sure that one works good too, not sure if it works 10x better though.
Old Jan 15, 2009 | 08:17 PM
AK Rover's Avatar
Here's my thinking on the matter.
1. I've never had any luck with the cheapo kits. Probably operator error (throw that out before sloppyjoe does) but I don't like to take chances with the brakes.
2. I've spent a lot of money on the rest of my tools, why skimp on a brake bleeder setup.
3. I know that it will get used enough to justify the cost. I have 2 vehicles of my own and seem to get roped into working on others vehicle because I have the tools. I haven't priced having a mechanic bleed and/or flush the brake system but I do know my mechanic charges a minimum of a half hour shop time or $46.25 every time I bring the truck in. At that rate I figure I could off set the cost really quick.
I appreciate the input guys, even if it does seem like I'm arguing with you. I really do.
Old Jan 15, 2009 | 08:34 PM
tomfraser's Avatar
I get what you are saying
If I had the cash, I would be doing the same thing
SpeedAgent
Sep 9, 2024 11:19 AM
ThisRoverGuy
Dec 27, 2013 07:00 AM
LeakyDisco
Nov 29, 2011 07:08 AM
Disco Alan
May 15, 2009 12:43 PM
jim jones
Nov 18, 2007 06:59 PM
