Brake Bleeding ?
Old Mar 15, 2008 | 12:17 PM
KeizerRover's Avatar
Default Brake Bleeding ?
I have seen the recommendations for manual 2 person bleeding, like is done on many other vehicles, to be utilized for a 2000 Discovery II. I have also read that in order to properly get this done you have to take it to a dealer with some super computer equipment to purge the system. What gives? Is the computerized bleeding only needed on newer models of LRs?
Thanks
Old Mar 15, 2008 | 01:24 PM
Default RE: Brake Bleeding ?
No, you don't need to unless you actually trapped a lot of air in the ABS unit. 2 person bleed works great, pump the brake pedal 3 times and hold it down while someone opens then closes the bleed screw. Continue to bleed the brakes, starting with the r/r then l/r, r/f and finsish with the L/f. Bleed each wheel till the brake fluid comes out clear, usually takes at least 1 quart of brake fluid, sometimes more.
Might try using Vavolines systhetic fluid which lasts longer.
SpeedAgent
Sep 9, 2024 11:19 AM
RoveringAgain
Nov 24, 2010 05:15 PM
allensp38
Dec 31, 2009 12:15 PM
Disco Alan
May 28, 2009 05:21 PM
Elhoff
May 29, 2007 11:13 AM
