Brake caliper bolts seized up
I used a mallet. It was the only thing that could get them to budge. I wacked them pretty good.
And even then, a couple others, I had to jack the truck up, put a jack stand under the wrench, lower the truck and use the weight of the truck to loosen the bolts. Probably not the safest way, but it was the only thing I could do to get mine loose.
Thanks man. I tried the rubber mallet to no avail. But I finally figured it out. If anyone else is stuck on the bolts, 1/2 socket, connect the rover tir iron extension bar, and finally connect a four way tire iron. If with over three feet of leverage it took some force to break these suckers lose:
OffroadFrance (04-11-2017)
It's not necessary. It's just a retaining screw to hold the rotor on as it went down the assembly line. The wheel holds the rotors in place just fine. If you really want to replace them, you can, but next brake job, they will be all rusted in there and you will need an impact to get them out! That was the longest part of my brake job was getting those dang retaining screws out. I say leave them out!
Another little tip I can add - the pb blaster works, Kroil works better ( Penetrating-Lubricating Oils ), or another product that a couple local garages showed me -
It's basically got some cooling agent to it so you can heat where the bolts go in, then hit it with this stuff causing the metal to shrink faster, often breaking the rust seal.
Another tip - hit the head of the bolt really hard. It'll brake the rust free before damaging the threads. Just don't miss and mangle the head of the bolt.
Dave
Dave
carnellm (04-10-2017)
