Brake Flush/bleed
Brake Flush/bleed
1998 Disco 167k miles...Reclamation
Brake overhaul in process
I plan on replacing everything with a brake rebuilding kit from Atlantic British (standard rotors/Ferodo pads)
I have bled brakes before but thought you needed special equipment to completely flush the system (especially with ABS)
I see no reference in the RAVE CD what's the procedure??
RE: Brake Flush/bleed
Hey Old Gold,
Just did mine this past weekend, not a bad job.
Took me about 32oz to flush the system, might take more in yours, depends on condition of old fluid.
Started with the right rear, then left rear, then right front, and finally left front.
You have two choices:
1 have someone pump, while you bleed the line.
2 purchase an evacuater (spelling?) and do it yourself, around 40 to 50 bucks.
First time I ever used a hand pump evacuater, but was an easy one man (or woman) job.
Took about 15 minutes per wheel.
When the job was completed, brake pedal felt noticably firmer.
Good Luck!
Good Luck!
tunernewb92
06-23-2009 04:44 PM
