brake job
Old Jun 1, 2007 | 07:52 PM
ciocc's Avatar
Default brake job
Hi guys,
My rear pads and rotors need to be replace. I have the parts, but not the know how. Does anyone have a link or a good source of 'how to' for this job. I'm fairly mechanical, and have a couple friends that I could call on for help if need be. Thanks!
greg
Old Jun 1, 2007 | 08:17 PM
Default RE: brake job
If you want to call me I can walk you thru it.
Mike
303-862-7680
Old Jun 4, 2007 | 04:47 PM
hoberock's Avatar
If you have a service manual, it has the steps....... Unfortunately, you have to pull the hub bearings and such. Not a very good design. You should repack your bearings while you are in there.
Tim
Old Jun 5, 2007 | 07:03 AM
llesra's Avatar
order this. its a free rave cd and it will answer this and future jobs
http://www.rover-renovations.com/Rave-CD-p/rave.htm
Old Jun 5, 2007 | 01:36 PM
ashu01's Avatar
Friends,
I need help with my Discovery 1996 model. I am having problem with the brakes; have already change master cylinder, pads, rotor, calipars...but still after a week or so i have to stand on the pedals to stop my ride. There is no leak, my tech is surprised and has not seen this problem before. I wanted to check if anyone had this problem and what is the solution for it? your response will be highly apprecaited.
Ashutosh Kaul
Old Jun 5, 2007 | 02:00 PM
llesra's Avatar
it might be because the brakes are new and arent completely bedded. it takes nearly 1000 miles before the brakes are broken in.
Old Jun 8, 2007 | 11:11 PM
mordor110's Avatar
Is the brake booster working OK? Vacuum lines all hooked up?
jroy
Apr 21, 2012 06:42 PM
EuroStyle
Feb 20, 2011 09:40 PM
Brad S1
Apr 12, 2008 07:22 PM
Landdaddy
Jun 8, 2006 03:34 PM
surf9ska
Feb 14, 2006 03:52 PM
