Brake Job, a NO GO [PICS]
Old Sep 6, 2009 | 08:46 PM
Torancis_LR's Avatar
Originally Posted by lipadj46
Are you sure those are your caliper bolts and not the hub bolts?
I don't know, that's why I have pictures.
I just followed this link http://www.discovery2.co.uk/brakes.html
Though, everyone keep saying the 12-point bolt is 19mm, where mine was 13mm. Any explanation?
Old Sep 6, 2009 | 08:48 PM
98roverguy's Avatar
Originally Posted by Torancis_LR
Where in the world did you guys get that I have a leak? I think there was a misconception on Disco Mike's part. I did not mention anything about leaks. This was a brake thread.
There are NO leaks. No brake fluid leaks or hub failure. Nothing!!!
If you thought I had leaks because of the pictures, it was just brake cleaner that hasn't dry yet.
O.K. Relax guy.
It looks wet, that's all.
Old Sep 6, 2009 | 08:56 PM
Originally Posted by 98roverguy
O.K. Relax guy.
No worries. I'm not raising my voice, I'm just informing.
Old Sep 6, 2009 | 09:01 PM
salve7's Avatar
I switched to EBC pads and rotors a couple of thousand miles ago and they haven't made a sound, even when they were bedding in. I've heard of premature warping but it was only from one guy. So far no brake dust either.
Old Sep 6, 2009 | 09:40 PM
waynehicks's Avatar
6th Gear
,Dont try and deny your leak now, they are on to you.
Old Sep 6, 2009 | 09:46 PM
You are on the right bolts.
You may need to wiggle them too.
Old Sep 6, 2009 | 10:01 PM
Thanks Spike, that's what I want to hear.
Cheers to you!
Old Sep 6, 2009 | 10:03 PM
98roverguy's Avatar
Ha!
Old Sep 6, 2009 | 10:05 PM
98roverguy's Avatar
That's good to know. Thanks for the update!
Old Sep 6, 2009 | 10:45 PM
Urban Panzer's Avatar
The bolts are threadlocked, so they are tight to remove.
I would remove, / undo them as far as you already did, then spray some penetrating oil / dis assembly fluid like Plus gas and let them soak for a bit.
Try to get some down the gap between the face of the hub and the caliper as well..
As far as your bolts being 13mm, well I cannot be 100% mine were 19mm, I may have made an error when writing the page, but will check it out and correct it if need be.
