Brake Job, a NO GO [PICS]
Old Sep 6, 2009 | 10:52 PM
  #21
handsome rob's Avatar
If you can get a hand held wore brush on the ends that were exposed it could do you some good, along with the cleaner and PB it should make the job easier. In some cases I have used a torch to liquify the threadlock but I do not know if this is a case where it is possible.
Old Sep 6, 2009 | 10:55 PM
  #22
Rover Chris's Avatar
so nothing on your land rover is leaking huh? lucky you!!!!!
Old Sep 6, 2009 | 11:10 PM
  #23
Torancis_LR's Avatar
No leaks. (Knock on wood)
Old Sep 7, 2009 | 08:41 AM
  #24
LR uses Loc-Tite on EVERYTHING, and since this is your trucks very first brake job...
Old Sep 7, 2009 | 12:58 PM
  #25
Suede's Avatar
Originally Posted by Urban Panzer
As far as your bolts being 13mm, well I cannot be 100% mine were 19mm, I may have made an error when writing the page, but will check it out and correct it if need be.
Yep. They are definitely 13mm.
Old Sep 7, 2009 | 01:03 PM
  #26
Suede's Avatar
Originally Posted by Spike555
2 steps forward and one step back.
Loosen them until they give you fits, tighten them back up a turn or two, loosen again.
Yep, Thats the way to work at em. Also, stop by home depot and pick up a 3 ft piece of iron pipe to slip over the handle of your ratchet to extend it. Will give ya much greater applied force with less effort.
Pull, pull, backoff. Pull, pull, back off. Cuss, take a chug of beer, cuss. Pull, Pull, backoff. It'll take about 1 pint of beer per bolt...
thehun
Mar 7, 2013 01:35 AM
jayv
Oct 7, 2010 09:15 AM
lipadj46
Aug 27, 2009 11:23 AM
Landdaddy
Jun 8, 2006 03:34 PM
surf9ska
Feb 14, 2006 03:52 PM
