Brake Light Switch and Brake Booster
Old 08-28-2014 | 01:06 PM
shezm's Avatar
Default Brake Light Switch and Brake Booster
I recently changed my brake booster to resolve an issue with weak brakes. The issue is fixed but I now have another problem...
The brake light switch's plunger will not reach the brake pedal arm anymore. There seems to be a .25" gap between the two. So my brake lights stay on at all times.
Did I install the wrong brake booster? I bought a used one from a recycler on eBay and I'm not sure which year Disco they pulled it out of.
Old 08-28-2014 | 03:59 PM
TRIARII's Avatar
Did you buy a new or used booster? If new where? If it was from Atlantic British then be aware that the list the wrong booster for the D2! I ordered a new booster from AB for my 2004 D2 and it was noticeably smaller (thinner) vs the booster I pulled from my truck. I called them and they sent me a second booster complete with a return label and that was was also thinner. Took a hour long conversation on the phone with them and a 3rd attempt for them to send me the correct replacement brake booster. Ill upload a picture later.
Old 08-28-2014 | 06:30 PM
abran's Avatar
He bought a used one off ebay.
Old 08-29-2014 | 06:32 AM
shezm's Avatar
Yes I bought a used one. The cost difference is so much it didn't make sense to buy new.
Fwiw the one I put in looked visually the same as the original. I hope to tinker with it this weekend; hopefully I find an easy fix.
Old 08-29-2014 | 06:46 AM
abran's Avatar
Why not put a piece of adhesive backed neoprene or some sort of shim on the brake pedal arm and call it a day.
I'm not hating on you buying it from ebay, those boosters are ridiculously priced, I was just clarifying!
Old 08-29-2014 | 07:02 AM
drowssap's Avatar
not that you should have to do it, but the plunger is adjustable on the master side i believe.
Old 08-29-2014 | 07:42 AM
shezm's Avatar
Don't worry I never took offense to your post. I have actually thought of shim as well. I may just do that hah
Old 08-29-2014 | 07:44 AM
shezm's Avatar
Awesome.
The plunger was slightly loose in the booster; I believe I turned it thinking I was tightening it but I may have caused my current issue by doing so.
Old 12-28-2015 | 03:41 PM
demson's Avatar
Default Weak brakes?
What did you mean by weak brakes?
Old 12-28-2015 | 11:15 PM
Best4x4's Avatar
Try this, remove your brake light switch, pull the plunger out (pull hard), push the brake pedal down, then re-install the brake light switch, let go of the brake pedal, and it should adjust itself. That should take care of your brake light issue.
Quick Reply: Brake Light Switch and Brake Booster
