Brake Lights / Park Lock
Old Mar 25, 2017 | 09:08 AM
Luckyjayb's Avatar
Originally Posted by gulfstream69xr7
Fantastic, thanks.
no problem man
Old Mar 26, 2017 | 10:12 AM
gulfstream69xr7's Avatar
I figured you all might want to know what the problem ended up being, so that if it ever happens to you, you won't as stumped as me.
Put the volt meter to the fuse box at F25 ( thanks luckyjayb) and I've got power. Then check the connector on the pedal, 14.2V.
Hmm, got power at the pedal, should work. I jump the connector and presto, bake lights go on and park lock releases.
Take a closer look at the brand new switch, and pigtail adapter, and what do you know, it's wired backwards.
Run around the corner to Advance Auto and pick up one of the old style switches, plug it in, and what do you know, good as new.
Yes, the new Land Rover brake light switch pigtail adapter was wired backwards. If you can find it. just use the old style part.
Thanks for all of your help.
Old Mar 26, 2017 | 10:14 AM
Luckyjayb's Avatar
glad you got it man.
Jason
Old Mar 26, 2017 | 09:06 PM
mln01's Avatar
Good Lord.
Old Mar 27, 2017 | 01:42 AM
MrValingo's Avatar
I couldn't get mine outta park at the gas pump. Some fiddling with the switch got me home. Took the switch apart and some dirt was mucking up the contacts. Good as new meow
Old Mar 27, 2017 | 07:10 AM
jamestfl's Avatar
mine was stranded at a gas station yesterday with the stuck in park portion of this. Not a fun time. Turns out mine was/is switch on the gear selector. Is that the neutral safety switch?
amer_qureshi
Jul 10, 2024 02:03 PM
Broken08
Jul 16, 2016 04:15 PM
mattrickman
Jan 17, 2011 10:07 AM
Lil-Kim-got-My_sandwich
Jul 30, 2010 06:43 PM
