Brake master removal on D2
Old Apr 3, 2014 | 12:23 AM
ls1morethanyou's Avatar
Thumbs up Brake master removal on D2
Here is what i did for my D2
Tools 13mm open wrench and socket- towels, drip pan- hope your brake booster holds out!
here it is on all its glory
Close up
Remove left side brake lines- you will need something underneath to catch the brake fluid
remove the right side nut
remove the left side nut
What it should look like after its out
Pull the metal bracket to get the cylinder off
Leaky grommets
Grommets removed and holes were cleaned after the fact
New grommets
Assemble the reservoir to the cylinder ensuring the wire is over the tab
Re-install the unit making sure the shaft inside goes back into the cylinder , all the brake lines and nuts and add liquid and bleed
Sadly for me my brake booster made a popping sound and now i hear air being sucked in... so more money ill get to spend now.
and my car got hit not too long after i got back from buying brake fluid.
Old Apr 3, 2014 | 12:35 AM
anyone know the size of the two thin rubber "o"rings, my brake booster is leaking from there.
to note, i also did not have a visible "o"ring when i removed the unit.
SolAeon
Jul 10, 2012 09:05 AM
colton
Dec 10, 2007 12:14 PM
ajh
Oct 26, 2007 02:58 PM
larry99discoI
Aug 22, 2007 02:35 PM
leebuhrul
Feb 26, 2006 03:38 AM
