brake noise
Old Nov 22, 2011 | 02:08 PM
sorusty's Avatar
Question brake noise
Okay, so i replaced the brake pads on all four tires this past week. i have had the truck for almost a year now and i am still finding out that the previous owner did not do any maintance to the truck at all while they had it. anyway, the old pads were worn down to almost nothing. I put the new pads on and everything works great but the problem i am having is that they sometimes still squeal. I mostly notice when i pull up next to something like in the drive thru they get loud. Anyone got any ideas on what is should do or check? the rotors looked good when i replaced the pads.
Old Nov 22, 2011 | 07:02 PM
lordmorpheus's Avatar
Did you apply lubrication to the caliper pins, and all places the brake pads contact the caliper? The main cause of noise on brakes is from vibration, and the lubricant helps with this.
Old Nov 23, 2011 | 10:29 AM
Where did you buy the pads, what brand are they and are you getting black brake dust on your front wheels?
Old Nov 23, 2011 | 12:31 PM
sorusty's Avatar
i got the brake pads from autozone, they are the duralast pads and yes, i am getting brake dust.
Old Nov 23, 2011 | 12:32 PM
dgi 07's Avatar
Originally Posted by lordmorpheus
Did you apply lubrication to the caliper pins, and all places the brake pads contact the caliper?.
X 2
Also, did you clean all your mating surfaces. (Pad to caliper)
Old Nov 23, 2011 | 07:35 PM
bmw zhp's Avatar
Originally Posted by dgi 07
X 2
This.....had the same problem this fix it.
Old Nov 24, 2011 | 07:26 AM
There is your problem, Disco 2 ABS units need high end, dustless pads. Akebono ceramic pads are by far the best.
If yoyu want help with this, send me your number and I' call you.
david4ducati
Mar 1, 2015 07:59 PM
30more
May 28, 2012 05:01 PM
redbaron586
Nov 16, 2008 10:06 PM
adrianwood
Freelander
Jun 13, 2005 08:53 PM
