Brake Pad suggestions
I think I am in need of brake pads and would like to know what do you people recommend. I would also like to know how many miles do your brake pads usually last. I know that it varies depending on the driver, driving conditions and load, I just want to have a rough idea. The brake pads that I have now are TWR and have lasted 3 years/23,000 miles. 23,000 miles doesn't seem to me like much but maybe it is normal for a Land Rover. I am an easy driver and on my Volvo I usually get 40,000-50,000 miles out of the brake pads.
I only changed my Rotors due to wanting to start over fresh and the fact the PO said they had never been done, but the Akebono's will not let you down. They are all over amazon and at a pretty good price. Best of luck
When I bought my truck it had OEM pads on it, they lasted about 60k.
I have since put Duralast brake pads on it and I like them, little to no dust.
They were noisy at first but they are quiet now.
As a FedEx driver, brake pads is brake pads, the only real difference is the amount of dust, stopping power is the same.
I have used el'cheapo pads and top of the line super expensive pads, the only difference besides the price is dust (cheaper ones had more) and life, the expensive ones lasted longer than the cheap ones but still not worth the cost.
So middle of the road brake pads from NAPA is what I use and they last about 2 months.
When I bought my truck it also had the OEM pads and they lasted about 50k. The pads I have now have only lasted 23k. That is why I want to make sure I get some good pads this time. I would also like to know if anybody knows what is the minimum acceptable thickness for front and rear rotors. I am hoping that I don't have to change them.
As for trucks, anyone who is towing in hilly areas should be particularly concerned about the quality of their brake pads and how well they handle heat fade.
