Brake Pads
Any pad you can get at atlantic british or akebono ceramic. If you want to go cheap roverguy has some budget OEM type pads that play nice with the 3 amigos. I am using them now and I would buy them again or the lockheed pads. I may try the greenstuff pads just to see if there is a huge difference but I doubt it. I hear they wear fast too. Akebonos sound like the best for low dust and low squeal but I hear they are a little scary when cold.
The stock OEM pads work good from the dealer. They do put out alot of dust though. Some sport pads like Hawk HPS pads work really good when they are hot but when cold they need alot of pedal pressure. I found the dealer was cheaper then schucks. I will buy OEM again along with OEM rotors.
Willie
Willie
Willie
Willie
