brake pads an rotors
You will get a ton of different opinions on this. Every person has a favorite or right answer.
I like EBC a lot.
https://www.lucky8llc.com/collection...-and-rotor-set
I like EBC a lot.
I am running cross drilled/ slotted rotors from Lucky8 with Akebono ceramic pads, no issues whatsoever. My LR guy says it's overkill, that the standard rotors and pads will suffice, however I love them, brakes better and no brake dust in the wheels anymore. I also did stainless lines at the same time.
Unless EBC Green Pads have changed their design I've never owned a set of brake pads that left so much goo on the rims in my life!!!!!
The Power Stop stuff I've been using leaves barely anything on the rims, and it's 156.00 for all 4 rotors (cross drilled/slotted), and F/R Ceramic Brake Pads. Sorry for the price they can't be beat.
I've installed em on 5 D2's and even my wife's LR3. They stop great and I've never had an issue. When I used to run standard Rotor's on P38/D2/LR3's eventually I'd have issues due to excessive heat. With the cross drilled/slotted that has never been an issue since.
