Brake pedal soft
Old Apr 11, 2007 | 11:18 PM
jwmstang's Avatar
Default Brake pedal soft
My brakes went bad and I relaced them. After replacing them I also bled the brakes. The pedal is soft and spoongy. I can stop but if there ever was an emergency forget about it. They weren't like this before the brake change. I did have to leave my disco sitting for about a month without driving it. I did start it and took all the usual precautions. My ABS light is on, however it has been on since about a month after I bought it. I have driven it for over a year with no problems until now. Thank you for ant advice.
Old Apr 11, 2007 | 11:21 PM
okdiscoguy's Avatar
Default RE: Brake pedal soft
I know it sounds a little redundant, but have you tried bleeding them again? sometimes the master cylinder gets a little low and sucks in air. Then you have to bleed them again...
Was it squishy right after you bled them?
Just out of curiosity, did you change your rotors too? What type of pads did you use?
Old Apr 11, 2007 | 11:27 PM
jwmstang's Avatar
I used a "one man brake bleader" would a vac bleader do any better? I did not replace the rotors. I did buy Bendex pads from Advanced Auto Parts.
Old Apr 11, 2007 | 11:31 PM
okdiscoguy's Avatar
If you can have someone as a pedal pusher, that is the best way in my book. I tried one of those vacuum bleeders on my BMW and ended up making it worse. I am sure it was just me, though.
I prefer to have someone stand on the pedal, so I know I am not getting any air in. It took me 2 weeks to convince my girlfriend to sit in the truck and do it, but I got a big difference. If it isn't too much trouble, try it. Someone else might have another idea.
Good Luck
Jason
Old Apr 12, 2007 | 12:16 AM
shagybruce's Avatar
X2 with the (manual bleeding) it does take a little longer but you do get a better (feeling) pedal.
Old Apr 12, 2007 | 10:24 AM
X3 on the 2 man bleeding.Buy 2 qts. of brake fluid and redue the flush to get rid of the air. Once that is done, if you want more pedal pressure, replace the rubber brake lines with stainlees steel, they don't expand like the old rubber hoses and in general work much better.
Mike
Old Apr 12, 2007 | 03:46 PM
Aquaholic's Avatar
2 man bleeding! And change the fluid - brake fluid isn't good forever.
stb616
Sep 19, 2014 06:10 AM
binvanna
Oct 30, 2012 12:07 PM
hotdogpimp
Apr 27, 2009 12:21 PM
m1964
LR2
Nov 17, 2008 09:49 PM
reconram
May 9, 2007 08:43 AM
