Brake Repair
Old Apr 25, 2016 | 07:48 AM
redrover75's Avatar
Default Brake Repair
I had a shop replace the pads, rotors the RR caliper last week.
When I drove home, the LR wheel was smoking and the rotor was blue. From self-heat treating I imagine.
They claim it is just not bled properly an that should fix it.
I drove about 15 highway miles since then.
What do you think needs to be replaced? Pads, rotor?
Thanks,
Old Apr 25, 2016 | 08:12 AM
cappedup's Avatar
Can't see how not bleeding would cause a rotor heat issue.
Pads need to 'bed in' for the first few miles. During that time you run a risk of being too heavy with them, and creating a hard, glassy layer on the surface. This lessens braking effect, so you press harder, making it worse. They should have explained that to you.
Are you saying everything is fine, after the 15 miles? Or you still have an issue?
Old Apr 25, 2016 | 08:22 AM
redrover75's Avatar
I am familiar with bedding them. I normally do all my own work, just not time lately and these had to be done.
This morning, the second time i drove it. My unscientific test was touching the rotors after i parked. The RR was fairly warm. The LR was too hot to touch. There definitely some drag or other issue with the LR brake.
Old Apr 25, 2016 | 08:52 AM
drowssap's Avatar
You most likely have a sticking caliper. If they got that hot, then the pads probably have heat damage now too.
Old Apr 25, 2016 | 10:45 AM
Best4x4's Avatar
Sticking Caliper or a stuck guide pin.
Old Apr 25, 2016 | 12:28 PM
cappedup's Avatar
Hello Drow....
Something sticking. Guide pins are easy to swap, and great for peice of mind. And cheap.
Old Apr 25, 2016 | 01:05 PM
drowssap's Avatar
Yes sorry, guide pins are also a distinct possibility.
Originally Posted by cappedup
Hello Drow....
Old Apr 25, 2016 | 02:46 PM
redrover75's Avatar
Default resolution
It appears they are saying the caliper is sticking.
They are replacing the caliper, rotor and allegedly the pads. Charging me $30 for brake fluid and $85 for the part.
I am pretty sure they screwed up and trying to CYA.
Old Apr 25, 2016 | 03:01 PM
cappedup's Avatar
Well, that's a touch irritating, as you don't get to check out the guide pins, which I think the full kit cost $12 for all corners.
As it's not the one they fitted, can't really argue. You will end up with two new calipers on the back. Which is nice to have I 'spose.
Old Apr 25, 2016 | 03:21 PM
redrover75's Avatar
I know, don't remind me. That is why i dislike having someone else do my work. But that is cost of not having time.
SeanPaul
Jan 22, 2016 05:03 PM
TennesseeRover
Mar 19, 2014 08:16 AM
zee
Jun 20, 2012 07:50 PM
Shaymer
Dec 3, 2008 10:22 PM
