Brake rotor recommendation
Old May 17, 2021 | 01:01 PM
Discorama's Avatar
Default Brake rotor recommendation
I already ordered Akebono brake pads, which were recommended here a lot. I am still undecided on rotors. Are the slotted and drilled on lucky8 (Terrafirma?) worth it or should I just go with plain OEMs? I go mostly overlanding, fully loaded and with kids, but not severe offroading, not driving through deep mud or dirt.
Old May 17, 2021 | 01:47 PM
redrover75's Avatar
I have had good luck with the powerstop one, I have been using their slotterd, drilled ones for a couple years. use them on other vehicles, incl a gls450, which is super heavy and I drive it at 100mph all the time.
Old May 17, 2021 | 02:24 PM
Discorama's Avatar
Do you have the part numbers? Thanks.
Old May 17, 2021 | 05:45 PM
JUKE179r's Avatar
EBC GD Sport Drilled & Slotted Rear Rotors #GD957 & Front Rotors #GD994.
Old May 17, 2021 | 06:03 PM
Best4x4's Avatar
Powerstop stuff on my Kalahari and zero issues. Stops great. Got everything from Brake Motive on Ebay for around 235.00.
Old May 17, 2021 | 06:05 PM
Gripen's Avatar
I have a set of Brembo UV coated rotors installed within the last few months. No issues and the rotors are still clean.
Front p/n: 09A22911
Rear: 08683811
Old May 17, 2021 | 06:42 PM
04disco2va's Avatar
Have these as well and happy with them. Definitely perform better than stock. Be cool if they stayed black !
Old May 17, 2021 | 07:21 PM
Art H's Avatar
I have never been happy with drilled rotors on anything I have owned. Slotted: yes, Drilled: no. Right now I am running slotted rotors from DBA with some nice heavy duty hawk pads. I really need to flush the system and replace the flex lines
Old May 18, 2021 | 01:20 PM
Discorama's Avatar
What is the disadvantage of drilled rotors?
Old May 18, 2021 | 01:37 PM
Gripen's Avatar
Eventual cracking. The drill holes are big stress risers for the brake rotor. Over time, the thermal cycles that a rotor experiences will cause cracks to develop around and through the drill holes.
