?Brake Servo?
Old Oct 23, 2009 | 01:04 PM
ghostrider747's Avatar
Default ?Brake Servo?
I was at a stop light and the brake rapidly(3 to 5 sec.) went to the floor. The pressure came back after driving around, then at the next stop light the same thing. Would this be the brake servo telling me its time to be replaced?
Old Oct 24, 2009 | 09:21 AM
On a D1, most likely your master cylinder is failing, is it leaking and if so has it gotten into the booster? How often do you change your brake fluid? Dirty fluid is one thing that will kill your master cylinder as well as the ABS module.
Old Oct 24, 2009 | 05:33 PM
I changed the fluid 6 months ago (syn. DOT5) with a good bleed to make sure that I only had syn. in it. It has not been leaking
Old Oct 25, 2009 | 02:30 PM
Master cylinder is bleeding internally, time for a replacement.
SolAeon
Jul 10, 2012 09:05 AM
TNdisco
Dec 12, 2010 10:09 AM
jlgolson
Jan 17, 2010 12:31 PM
salve7
Nov 23, 2009 01:00 PM
benflynn
Dec 26, 2007 12:55 AM
