Brake servo line connector
Old Dec 11, 2010 | 02:25 PM
TNdisco's Avatar
Default Brake servo line connector
Does anyone know where I can find the red connector where the servo line connects to plenum? I ordered the servo line from AB but it didn't come with fitting. Thanks so much, jeff.
Old Dec 12, 2010 | 09:52 AM
Fireman's Avatar
you are probably going to be stuck with trying the dealer or fabricating something yourself. I would check the dealer first; I find my dealer cheaper than AB for these small parts. Barring that, fabrication shouldn't be that hard. The connector is a quick connect that is typically used for low pressure pneumatic lines. You could possible use something like this:
This is available from http://www.gamurdock.com/gam/out/GRO...ngs-Female.htm, but you might get lucky and find something that would fit in Home Depot's water purifier or fitting department. I liked the one above because it is brass and less likely to break.
Old Dec 12, 2010 | 10:00 AM
Dealer or junk yard only.
Old Dec 12, 2010 | 10:09 AM
TNdisco's Avatar
Thanks guys, there is not a dealer anywhere close, I thought about fab something up, we shall see how it goes.
silar
Sep 26, 2019 04:49 AM
me6067
Jun 26, 2015 12:10 PM
elkinspd
Oct 23, 2013 03:51 PM
01d2Jeff
Feb 1, 2012 08:04 PM
jlgolson
Jan 17, 2010 12:31 PM
