Brake warning light?
Old 11-08-2009, 02:40 AM
Shadill's Avatar
Default Brake warning light?
My "brake" warning light came on the other day and won't go away, brake fluid is topped off, thought it could be either my pedal switch or my park brake switch, but my tail brake lights are working perfectly. What else should I look at?
Old 11-08-2009, 08:46 AM
The parking brake, make sure it is down all the way.
Pull it up, and then put it all the way down.
Old 11-08-2009, 10:28 AM
PalmettoDisco's Avatar
Also, the float on the brake fluid level sensor may have lost bouyance, thus sinking and triggering the brake warning light. They usually will fail slowly and make the warning light "blink" on and off as the sensor partially floats at the threshold of the warning level.
Old 11-08-2009, 01:57 PM
tornado_735's Avatar
I was going to suggest the float too. It's possible some crap may have gotten into the reservoir, and has jammed the float. See if the float is floating, and let us know.
Old 11-15-2009, 10:53 AM
Shadill's Avatar
Checked the float and even pressed it up to the cap and the light is still on, checked the p brake switch, pressed it all the way in and still no change. I still need to check my pedal switch, but it must not be the switches because my taillights work perfectly. I'm wondering if it has anything to do with the trailer brake system that the previous owner had installed
Old 11-15-2009, 12:38 PM
No, the trailer brake has it's on warning light.
Old 12-11-2009, 10:22 AM
Shadill's Avatar
Guys I'm still stumped on this one, i've tested my pedal, parking, and brake res cap switch, and they are all working, my res it topped off, but my brake light is still staying on. Could it be the brake module? One thing to mention, when I press the pedal, it makes a fairly strong clicking sound from the center console. Is this just the normal sound it makes when the tail brake lights come one? Thanks for any help, I should also mention that I have 3 amigos
Old 12-11-2009, 10:42 AM
Mrmerlin's Avatar
a click in the console may be the shifter interlock working
Old 12-11-2009, 04:41 PM
mag48's Avatar
I to am having the same problem. Could someone tell me how to check the float, what to look for, and the repair remedy. Thanks a bunch.
Old 10-20-2014, 04:12 PM
Disco Nomad's Avatar
I have the exact same problem. Did you ever figure this one out?
Quick Reply: Brake warning light?
