Brakes are alittle soft
I've noticed that my braking distance has been getting worse, and that the brake pedal is not giving me as much resistance. I have normal amounts of wear, and the rotors and pads were replaced at around 35,000 miles. I've currently got almost 49,000.
Any ideas?
Thanks!
John-Robert
Any ideas?
Thanks!
John-Robert
RE: Brakes are alittle soft
Had similar problem a year or so back.
My truck was jumping a little when I tried to stop from 45 miles an hour plus.
I drained my fluid, refilled with fresh new fluid and bleed the system. I had found for some reason the back brake lines had air in them.
After the new fluid and bleeding the problem went away. Have change pads and rotors since with no issues.
wease206
11-24-2009 10:20 AM
