Brakes are alittle soft
Old Oct 9, 2007 | 02:47 PM
johnnybob06's Avatar
Default Brakes are alittle soft
I've noticed that my braking distance has been getting worse, and that the brake pedal is not giving me as much resistance. I have normal amounts of wear, and the rotors and pads were replaced at around 35,000 miles. I've currently got almost 49,000.
Any ideas?
Thanks!
John-Robert
Old Oct 9, 2007 | 03:21 PM
Default RE: Brakes are alittle soft
Who's pads and rotors were put on, were the brakes bled??
Old Oct 9, 2007 | 06:45 PM
Landzu's Avatar
Change the brake fluid before anything else.
Old Oct 10, 2007 | 08:55 AM
hobiecat's Avatar
Had similar problem a year or so back.
My truck was jumping a little when I tried to stop from 45 miles an hour plus.
I drained my fluid, refilled with fresh new fluid and bleed the system. I had found for some reason the back brake lines had air in them.
After the new fluid and bleeding the problem went away. Have change pads and rotors since with no issues.
Old Oct 10, 2007 | 10:34 AM
Thanks for the reply!
I really have no idea which pads nor rotors were put in. I'm assuming its just the regular LR ones because this was done at the dealership.
Old Oct 10, 2007 | 10:50 AM
No more dealer pads and rotors!!!
I would suggest, if you have a soft pedal, that you get the brakes bleed, completely.
This would be something you and a friend could do if you wanted to save money.
SSchultz
Nov 11, 2012 11:04 AM
wease206
Nov 24, 2009 10:20 AM
m1964
LR2
Nov 17, 2008 09:49 PM
Rob S
Jan 5, 2007 09:44 PM
red rover 99
Jul 12, 2006 04:39 PM
